broncomatt
- Dec 27, 2005
- 284
Of all the trans swaps out there are there any that can have compression braking in all gears including 1'st?
I know this means a manual valve body but it seems no one makes one for the c4 in the revers pattern with compression braking in 1'st. I have one that is a forward valve body with compression braking in all gears, unfortunetly a screw pulled its threads out and caused the valve body to slip. Not sure I can get it repaired, not sure I want to since I like the reverse pattern.
