ARB air supply fitting location
Johnnyb
Flagstaff
I'd like to retain the original differential vent in my Dana 44 so that the brake line distribution block remains in the correct location.
Therefore, I have to create a new hole for the ARB bulkhead air fitting in the differential housing.
I was wondering what other people had done? Looking for ideas.
THX,
JB
bax
Old Member
Good question. I will soon be doing the same thing. I will pay attention
Pretty sure the kit comes with the bulkhead fitting and instructions on installing it. No need to re-invent the wheel. ARB already figured what you need to do.
gnsteam
Lincoln NE
THX,
JB
Here is a link to thread showing how I placed the ARB fitting on my Dana 44.
https://classicbroncos.com/forums/threads/dana-44-arb-bulkhead-fitting-placement.315500/
gnsteam
Lincoln NE
I also found a few more pictures of the relocation of the vent tube. To allow more clearance for installing the hard, brake lines. I made an adapter block to move the flexible brake line higher and behind the vent tube. I still need to make the new hard lines. I hope this helps.
Johnnyb
Johnnyb
Flagstaff
From my observations, that is only partially true. ARB does provide a bulkhead fitting, but it would replace the stock banjo bolt and brake distribution block. Not to mention, it would leave you without a vent for the differential as that space would be occupied exclusively by the ARB air supply line.
I'd love to keep my brake lines where they are and have a vent.
JB
Johnnyb
Johnnyb
Flagstaff
Compounding matters, my axle housing has not been removed so I will be drilling in place.
