Ok, so I have a 9" Bronco axle housing that was left out in the weather for a few years and I need to get it dipped or stripped or cleaned to make sure I can use it. I'm in the coastal Georgia area, half way between Savannah, Ga and Jacksonville, Fla. I haven't had any luck finding anything local to Brunswick, so I'm hoping someone can point me in the right direction. If nothing else, some specs/tolerances for the axle bearing and seal area for a big bearing '77 9 inch housing. Thanks in advance. And the housing was out in the weather in North Ga, not on the coast, salt air isn't good for anything but tanning, drinking, and sweating...
