- Dec 22, 2005
- 736
This extension makes it so you can mount your Bauman controller behind the right side of the glovebox on the outside and only have the face show through. In doing this you gain room inside the glove box and for testing you can just open the door to see the data. This opens up a new issue how do you access the connector if you want to plug in your laptop for adjustments or datalogging. Our new mountable extension cable allows you to plug in the cable wherever you mount it. You can mount the extension in the glovebox or you can mount it in the bottom dash trough facing down so it is not seen but accessible.
https://bcbroncos.com/shop/interior/dash/81-15050-17-transmission-controller-access-port-extension/
