- Dec 22, 2005
- 730
This bracket is a nice panel to cover the hole you cut into the passenger fender apron when you plug the Coyote engine harness into the computer. Once you cut your hole you can bolt this cover on to reduce and clean up the hole at the same time. You can paint it the body color or powder coat to match other parts.
https://bcbroncos.com/shop/electrical-and-lighting/wiring/81-15041-24-wire-connector-cover/
