lonicus
I got the transmission (finally) installed using the kick the tail housing to get the Trans in method. Actually went in fairly easily. It's an AX 15, so new pilot bearing, clutch disk.
Now I have the adjustment turned down pretty far - and since I'm using the stock 3-finger clutch shouldn't need much adjusting (did not need a body lift). I have a HUGE hole in the trans tunnel which made the install much easier (from PO) so I can access the tailshaft and the pedal at the same time.
With the pedal fully depressed, I cannot get the tailshaft to budge (not even a little play) when the trans is in gear - moves freely in neutral. I don't think the clutch is putting any clamp force on the clutch plate. Could I be binding on the pilot bearing somehow?
