Having done every possible combination of wrong, I decided to post my latest addition to my Project. I just installed my new exhaust system. I got tired of paying high prices for mediocre work. The last shop I used welded a hanger stud to my freshly powdercoated frame. Tired of cheap mufflers, and tired of poor workmanship.
So I decided to do it myself. (sort of.) I bought USED cat-back take off from a 2020 F150. Muffler is 2.5 inlet, 3 inch outlet, with a stainless tip. Early Bronco Factory cast iron exhaust manifolds into a 2.25 H-pipe from a 1970 F250. (The listings are wrong in the catalog, and the Walker 40516 + Walker 42371 do NOT fit a 302 in an F250. They are for a 360 FE engine. But they are 2.25 with nice tight bends.) Added a V-band clamp at the muffler, and a couple of o2 bungs. The 2.25 exhaust flanges are too big for a 302, so you need to buy a pair of 2 inch flanges.
I didn't want an exhaust pipe down the left side past the transfer case. There is no room, and it's in the way of everything. Also, when you get to the rear axle, the brake line, and gas tank get in the way. So the answer for me was a single exhaust in the factory location. The single exhaust on the F150 5.0 Coyote puts out 400 HP all day long. It's plenty for my EB.
Walker 40516 y-pipe = $55.
Walker 42371 crossover = $22
Walker 41772 collector (x2) = $11
Mahle F17250 donut (x2) = $3.19
APH 339820S hangar (x2) = $6
Summit 610400 hangar (x2) = $6
Summit 694250 v-band clamp = $35
reducer, 2 inch OD to 2-1/8 OD to center donut. (x2) $5.00 each.
Cat back take off - $100.
Total spent $268.38
If you can weld and fabricate, then this might work for you. My MIG skills are not great, but my welds don't leak. You do have to "unbend" the accordian bend on the left side head pipe to get it to hug the pan. And you have to cut and turn the muffler. and shorten the over-axle tailpipe. But for $268 (and a long weekend) I'm pretty happy.
The goal was an exhaust that would be absolutely quiet, non-restrictive, and idle all day long without annoying anyone. Needed to be serviceable, and allow for maintenence. The muffler is 7x12 oval, with a 26 inch body. I don't think a bigger one would fit.
Total spent $268.38
