Rymadd
- Jan 24, 2013
- 470
Hey so I'm redoing my rear suspension, and trying to get it all set up really good. First off I do everything high speed dunes, logging roads, mudding rock crawling, snow.
I pulled all my leafs out but the top two so I could flex it easy in my driveway. Sitting flat on the stock bump stops my rear tires are about 3" inches away from getting into my flares. However if I flex the rear axle, one tire compresses the flare and gets deep into the actual quarter panel.
I am measuring for shocks right now and wondering:
Are bump stops only for bottoming out the suspension at high speed (axle relatively flat to the body/frame) or do you guys set them up to stop your tire from flexing up into the body? I'm measuring for my shocks and having the shocks outboard of the bump stops makes it tricky because the shock can have lots of travel left when the axle is flat, yet bottom out when it is at an angle.
Thanks, and I have everything I need to fabricate whatever so I don't need to buy the 3" longer ones some of the vendors sell. I just want to set this up right
