biggercb
- Feb 19, 2009
- 125
I have a recently rebuilt C4 installed. When it is first started up, reverse works well. It's a solid shift, and it has plenty of power. During/after warmup, the shift to reverse gets "muddier" and eventually loses all power in reverse. When you rev the engine, it will have a sort of studder in reverse, but no real power. I have driven around the neighborhood and it does seem to have engine braking when I leave it in first. Manually shifting to second seems to work just fine. It will shift into drive just fine as well...but I haven't had it out on the highway to test and see how well it is shifting between the gears.
Fluid is correct, I am checking when warm, at idle, in park. I added about 10 quarts total between the initial quart or so in the torque converter.
I have been in touch with the guy who rebuilt it, but I have moved a couple hours away since I picked it up. I was hoping to avoid trailering it back up there if there was some knowlege on here I could tap into.
Thanks!
Thanks!
