Faster Eddie
I am also having wander buggy issues.
Have 2.5 WH lift installed, new 35" tires, (what PSI should I run? They filled up to the top at Discount tire), newly installed T style linkage on my '77, stock box that I was told "seems just fine", alignment was done after new linkage installed but don't know the numbers, new column, upper n lower shafts, everything is torqued to spec except for the drivers rear spring bolt. Seems the nut is stripped.
Other than my rear spring blot that may have play, do the angles look ok? Any help is huge!!
