OK Guys I'm tired ... I've worked on this carrier bearing on my Bronco Haul truck .
..2000 Dodge diesel .
But it's been viberating pretty bad lately . SO Before we load up & go get my Buddies new Bronco . I need t replace it. So took about 3 hours labor to get the shaft out from under the truck . & I could not knock the bearing off So I got out the hot wrench . SO It's off but that even took 30 minutes.
..... So too a flat Bastard & cleaned up the surface .It looks dressed fine ..
So tried to put the new one on no go. There were 2 style but they are about 1/4 difference so this is the correct one.
.... It wouldn't slide on . So I tapped on it somewhat. Still no go .
So I removed it. & recleaned the surface .. PUT IT ON AGAIN. AND PUT IT in the vice an got a perfect fitting piece of pipe ... Beat hell out if it no go.
TOOK IT OFF AGAIN . Got the file & dressed the complete circle for the 3rd time . You could even see the filings .. Cleaned it up again & tried to drive it on .. It's holding in the vice & I got that piece of pipe that fits over the spline
& inside the rubber & up against bearing .. & My BFH AFTER IT AGAIN. still no go. So
..... Have any of you had a issue like this before. & When that bearing does go on how loose is ok.
.... Also if the shaft is hot will it swell or Do I need to chill that shaft to shrink it. I guess I could go to town & get a sack of ice & put it in an ice chest..
THANKS
THANKS
