- Feb 29, 2024
- 48
Had a local shop install a new clutch and flywheel and for me a few weeks ago. 71 with 302 and stock 3 speed with duffys floor shifter. It was just a luk replacement diaphragm clutch.
My clutch linkage is all good, adjusted properly and everything seems to work as it should. I am getting a binding/sticking feeling in the clutch pedal which I tracked down to the clutch fork inside the trans. Seems like through the travel something is rubbing. I am not getting any type of throwout bearing noise or anything like that. It is noticeably better when its cold vs hot as well.
One thing I am fixing this week is the clutch pedal stop bumper is virtually gone so my pedal is is sitting very high. I have the correct amount of freeplay currently but maybe I am over extending when pushing the clutch in? The previous clutch had a really smooth clutch action. Shop used the throwout bearing that came with the clutch kit and is a very respected shop that I have always had a good experience with so I pretty sure the install is correct.
With the pedal so high the adjusted rod into the clutch fork is basically out of adjustment so hoping getting the pedal where it should be will get rid of that issue.
Anyone ever experience anything like this. Really dont want to have to drop the trans again.
