bluebronco69
soooo,
just installed the new heavy duty luk kit i got from BC broncos. 11 finger instead of three, much better pressure.
unfortunately more effort to push the pedal.
today while driving back from the gas station at lunch there was a pop when i put the clutch in... wierd, thought it was linkage or something, it still mostly worked, was hard to get into first, and would grind into reverse, no matter, i will adjust it when i get home.
when i got home i adjusted it a little, it worked better, took it for a drive and it got worse after a couple of pushes.
i looked around more, turns out that the bolt holding the clutch bracket onto the cowl, closest to the dash, is ripping out of the sheetmetal.
i assume it is a nut welded to the sheet metal (it is inside of a channel and i cant see it) but the channel is rusty and ripping out...
i have to use it for work tomorrow, so i pumped a couple of good sized sheet metal screws into the bracket, and it is working for now, hopefully it gets me through tomorrow, we will see.
anyone had this happen before?
i think i need to pull the dash, pedals, and linkage, then cut out the old metal, and in with some new...
