American Bronco Co. is pleased to announce a mass buy on the Hanson Rocker Panels
See Below for all the details
Available for:
66-77 Early Broncos
Description:
Hanson Rocker panels combine tough 3/16" steel, maximum bottom and side impact protection, and sleek styling. Panels attach easily with 5/16-18 truss head machine screws (provided) into side of tub and through body flange on the bottom or they can easily be welded in.
Hanson Rocker Panel protrude out 2 1/2" from tub for maximum door panel protection and 5" high on sides for the ultimate rocker protection.
All Early Bronco Rocker Panels are one piece.
The ends of all rockers are cut to fit stock Early Bronco’s without fender flares. The length can be trimmed to accommodate fender flares.
All products shipped bare steel.
Available Options:
Compound miter cut to match the flare angle. They are capped and ground smooth. Capping prevents the ends from distorting, as this is where the rockers will take a good percentage of hits. Capping the ends is an extra step that is worth the effort to create a much stronger rocker panel.
Construction:
All Rocker Panels - 3/16" Hot Rolled Steel
Pricing:
All Rocker panels - (All Years): $150.00 set Mitered and Capped: $250.00 set
Mass Buy requirements:
Minimum order for the mass buy is 12 sets (with or without end caps).
Price does not include shipping. You can estimate shipping at 60 pounds from area code 90650 using UPS. I can ship from California to Maine for $65.00
Lead time is two to three weeks once the mass buy has ended.
Only firm orders will be considered for the mass buy.
Mass Buy ends November 28th.
To Order:
Contact American Bronco Co. at 562-569-1991 or visit us on the web at www.americanbronco.com
Available for:
66-77 Early Broncos
Description:
Available Options:
Construction:
Pricing:
To Order:
