Hi all. Assuming the worst, but figured I would ask here before I start ordering parts and tearing the engine apart. Recently rebuilt the carb and while I was working on the idle speed, noticed a steady leak under the driver's side exhaust manifold. Blown head gasket? Worse?
Video is under the left side of the vehicle, looking up https://drive.google.com/file/d/1JD76ZETSGuD4yzu6nLlmyI4cLMzfEjqS/view?usp=share_link
- Oil looks fine, not milky
- Loud hissing sound when engine is turned off
- No leaks above manifold
- White smoke leaking out of an exhaust joint
- Oddly enough, at normal operating temperature and after a drive, coolant is cool to the touch. Basically room temperature, as opposed to the heat above.
- I can see corrosion around the exhaust manifold
Appreciate the help.
