I dropped my tub off at the blaster today.
tub, windshield frame, fenders, tailgate will be about $150 to blast ($75/hour). I am not having all of the inner rear quarters blasted, nor are the core support, floor, hood (fiberglass), or front floor boards. Other plans for those. Would be another hour ($75) to blast those.
To epoxy prime all of that (No body work, no filler, just spray the freshly blasted parts so it doesn't rust while I do the body work) would be an additional $650 for PPG DL90 Epoxy primer ($100 for the paint, $100 for wax/grease remover and other bare metal prep), and $450 for two coats of the epoxy primer and use of their area for proper cure time)
For the next step, 2K high build primer/block sand/ Urethane top-coat / Urethane Clear Coat, would be another $1800+. ($300 in paint, the rest in hours to block & sand and prep the body for the top coat, including proper cure time for a very very durable finish)
Another place, which I didn't use, to soda blast the entire tub, fenders, grill, etc... and epoxy prime (plus do very miner filler work, just that which annoyed the paint guy) for $1800.
Another place, to sand blast, prime, block-sand, top coat (single stage non-metallic) was $2000 - and included a very slight bit of body work. But they wouldn't use epoxy primer, something about their cleaning system or some bs, so I didn't use them.
Maaco wouldn't touch my EB, they were dicks about it, and wouldn't warranty the work... but wanted $800 to prep the old paint and put their crappy paint job on it.
Notes: make sure you use an experience person to sandblast the sheetmetal, it can warp and distort if they don't know what they're doing ( I screwed up a piece of sheetmetal I was just playing around with )
