SaddleUp
Jesse was one of the first I spoke to. The 1350 still uses the same 1/2" center pin though which is what I have been breaking so there doesn't seem to be a great advantage in using it over the 1330. I've also spoken to most of the others suggested here and they pretty much confirmed the same thing. FWIW, Jesse was the only one that pressed me to upgrade to the 1350 CV even though he pretty much said it wouldn't help my problem. I.E. He is the only one that seemed to be trying to sell me something I don't need. I'm sure what he does is great stuff though. I'm just not going to spend 5 or 6 hundred bucks on this when can stockpile 8 or 10 drivelines for the same money. As to limiting the center in the rearend I'm doing so already. That is probably what saved me from replacing the entire CV and allowed me to just rebuild the one I have the last time. (The previous two were hammered) I'm not worried about the axle end. I can probably twist the driveline in half before I have any problems with it.num said:jumping in late on this thread...
I have Jess' 1350 CV shaved for a good drop. Totally eliminates drive-vibe.
It's been working bomber for a few months and a bunch of trails, but another axle-wrap issue has developed. I have yet to bind the actual CV joint, but I've DESTROYED 3 axle-end ujoints. My driveshaft is currently hanging on my bronco right now until I figure out why exactly my rear axle is wrapping like heck. Either way, it's cheaper to carry around a stack of axle-end ujoints and I have yet to see a deformed 1350 yoke as a result of my beating. If the CV were to break often, that would be an issue to resolve. Jess at highangle puts together a 32* 1350 CV for a decent price. He offers a 42* option as others do as well, but I would question the maximum RPM for that shaft even now. Still seems like a grey area. Friend of mine got Jess' 42* CV for the front of his beast 70s highboy ford running a d60 front, 44" tires, high gears, and fresh 460. It was perfectly stable on the highway and romping on the trail, but I would still question how much it could be trusted. It's also a considerable investment.
Have you ruled out trying to limit the center drop of the rear axle? It might be something to consider hoping it won't combat articulation in your case.
Anyway, see what Jess and Tom Woods have for shaft seeing as I have bought shafts from both. Great stuff - decent price - and cater to applications such as yours.
best of luck!
