I recently got my hands on a full width 31 spline 9". I would like to take the 3rd member out, drop it into my existing big bearing EB housing and get the 31 spline axles cut and resplined to fit. However, both of the F150 axles are the same length, whereas the big bearing EB axles I'd be pulling out are two different lengths (one is about three inches shorter). Will I need to get the F150 axles cut to two different lengths to match what I've got now, or do I get them cut to the same length since I will also be using the F150 third member?
If you respond to this post, please do not give me your best guess, if you don't know for sure, you can't help me :
