Dana 20 question
ltatro
Michigan
OK, I managed to drop this thing for the second time. This time to repair a bad seal. Trans fluid is filling my case. The manual makes it look like the gear cluster comes out with the adapter housing, mine didn't. Housing came off but the shaft and gear cluster are still on the TC. I don't see a spring clip or anything. Anyone that can help me get this thing apart so I can fix the seal. Tater
From the inside of the T-case, push the shaft, bearing and seal out the front. Then you will see what is holding it together.
L
ltatro
Michigan
Thanks Broncobowsher, opened up the inspection plate and with a little umph it popped right out. Thanks for the help!
