flousberg
- Apr 28, 2002
- 745
Tore apart the front yesterday to install the ARB. The old carrier was for gears below 3.92 and I am putting in 4.56 gears. The ARB questions say to measure from the face of the flange of the old carrier to the outside of the bearing race then measure the ARB to the outside of the main shim and subtract the two to get a starting shim pack. The problem is it is off over .250. I believe this is because of the change in carriers to the higher gear ratio. If this is correct, does anyone know how I can get a good starting point for the shim pack? Im sure I will eventually get it, but if there is a good way to estimate it, that would help.
