Dana 44 disk brake conversion question
DeepC73
I have been looking around trying to find the answer with no success. I have an opportunity to buy a set of 1978-79 F-250 Dana 44 Steering Knuckles and Disc Brake Mounting Plates. Will they work for a drum to disc conversion? Thanks in advance.
bax
Old Member
yes they will but they will be 8 lug.
Not sure if you can change out to a 5 lug hub with this or not.
Wes harden
Yeah iirc those rotors are 14 5/8" in diameter and 2 piston calipers. You will need 16" or 17" wheels too. Nice big brakes if you are going to run 35+ tires. Might even have the big ball locking hubs.
There is a guy over on another forum that is actually looking for the ones you have access to. Are they advertised, or just someone you know?
If they won't work for you do you want to pass the information on to the other guy?
paul
toddz69
Those won't work on our trucks without some machine work on the rotors and you'll need to run 16" or larger wheels as others have noted. There used to be an article online about that conversion but I think it's since disappeared.
Todd Z.
DeepC73
DeepC73
paul
Sorry, I’ve been offline for a few days. The parts are for sale on FB market place in Maryland.
