I shortened both sides on my HP44. That way I could keep my EB axles and adjust the pinion angle as needed. Grind the weld off both ends where the cast meets the tube. Cut tubing to length, press the cast ends back on and weld. Do one side at a time, so you have a reference for the pinion angle.
Mark
