Glad that worked for you MZ. Great looking setup!
The Duff knuckles are very nice. As said though, they're not exactly like the '76/'77 knuckles that your kit is designed for.
But you got it. Tiny bit of grinding and you're looking good to go.
Just make sure (if you haven't already) that the fit of the bracket is nice and easy, and not pushing up hard against any of the surfaces that might skew the caliper even slightly.
And I still have a worry about the caliper fitting the rotor.
Not for sure of course (because we've never tested them with that setup either) but because if it's based enough on the Super Cab knuckle, there could be an issue because the standard full-size truck and Bronco knuckles are enough different that some of the Wilwood kits are not compatible.
Crossing fingers and hoping this is not the case for you.
This is just a guess on my part, but I would bet that the Wilwood brakes are based around a Chevy design like most aftermarket parts...
I hear that! Still the way of the Auto world.
But at least in this case the 140-13305 Wilwood kit that he mentioned is in fact for the '76/'77 Bronco knuckle and should be as bolt-n-go as any aftermarket part to an OE part as we're likely to find.
Because of that it does not even fit the '76-'79 full size truck knuckle if I'm not mistaken. I remember a customer having trouble with his because it turned out his Ford disc setup was from a full-size and nothing fit quite right.
So not surprising it didn't fit the Duff unit exactly in this case. Glad it was an easy mod/fix.
So far at least...
Good luck MZ!
