broncbusted
I am installing Duffs extended radius arms along with the 3.5" lift kit on 1976 Bronco. This is a frame off resto and I am trying to get all the bolt holes and welding done so I can paint the frame. Going by the instructions, measuring back 10.25" from the .5" threaded bolt hole in the frame, two of the holes in the rear mounting bracket have .25" holes right on the edge of where I need to drill the .5" holes to mount the bracket. I know whats going to happen when I try to drill them, the drill bit will walk right into the .25" hole! If you have installed these arms you probably know what I'm talking about,it sounds confusing and I wrote it! Anyway for anybody that has these arms installed and in use I have a question. Since the rear of the arms are adjustable any problem with going back .5 to .75" more than the 10.25" to get the .25" holes out of the way? I have done a search on the site and I see some people have only put one or two bolts and then welded them in place. Sorry for the long post. Thanks for the help
