jhughes4
I'm new to this EFI setup, hopefully someone can advise:
I have a 1990 5.0 motor, and when I get fuel pressure up to about 30#, the #6 injector rail sprays fuel. I have not started the motor yet, just getting everything ready. Is this normal or is my fuel rail bad? I have removed everything, reinstalled the rail and all injectors are new. The rail is tightened to 20 ft lb(all 4 bolts)
Should I just try to start the motor and see if it still leaks or could it be some other issue?
