G's Baja Bronco
I was at the AutoZone earlier and was going to buy a thermostat and found that the stock 88-93 stang stat is 192 degrees, and the 96-97 exploder 5.0 is also 192 degrees, what should I run in Southern California, including trips to Imperial Valley desert and Baja. I am running an over-sized aluminum radiator and Mark vii fan, also an over-sized engine oil cooler, The thermal switch for the fan is 180 degrees from painless.
I was thinking a 180 would be ok, the computer might think I am running a little cold and richen the mixture, or should I just go with the 192???
would my gas mileage suffer with the 180?
