Exhaust close to transfer case
aggieland
Recently picked up a 1976 bronco that has a 302 engine. Didn't notice until now that the exhaust is touching the transfer case. Thoughts if this could create an issue. this is my first ever bronco, and I have very limited knowledge of exhaust lines or transfer cases.
full
1969
It looks like it’s touching the crossmember. I would have your exhaust redone and reroute it to the passenger side. It’s way to close to everything imo.
Your feelings are correct. That is not right. The exhaust should not be making hard contact with anything and only touching exhaust hangers.
That is wrong by being against both the transmission crossmember and the transfer case. I'm going to say that should be redone. Any decent exhaust shop will laugh at that work and redo it correctly.
It's not unsafe, you can drive it to the exhaust shop. It is just low quality work. And direct contact to the transfer case would make it run hotter after a long drive. I would not recommend a 200 mile road trip at highway speeds, the transfer case oil would likely get pretty warm.
BronCowie
Old Timer
Vancouver, WA
Welcome to our panel of experts. It seems unanimous that it needs to be redone. Don't forget to tell the exhaust shop not to laugh too hard! :p
Johnnyb
Flagstaff
Somebody thought they were being clever putting the exhaust inside the crossmember. It does keep it up out of the way but I can't imagine that doesn't create a rattle and a heat transfer.
-JB
