Big Slim
- Dec 11, 2007
- 311
I bought an old SW tachometer and bench tested it and was calibrated so is working fine. it does not match OBD value when on the truck. have 98 explorer 5.0 with edis. i have the brown/yellow wire from the computer into the tach as the signal. this is suppose to give the same type signal as normally off the coil? or does this need something special for tach to work? EFIguys video seem to imply that this wire should work as is.
