City:
Madera
Price: $ 3000
Price: $ 3000
Explorer motor swap kit for your Bronco.
I purchased this set up on this site a while back and have decided to stick with what I have. All I have done since buying this is move it from cardboard boxes to plastic totes. All items have been stored inside and well cared for.
Here is the original listing...
2000 Explorer motor with 70K miles. Brand new water pump.
2000 Explorer 4r70w 4x4 trans. Completely rebuilt with zero miles on it.
Advance Adapters tail shaft to mount a Dana 20 t-case.
Brand new Torque Converter from the shop that rebuilt the trans.
Sanderson P-head headers from the Bronco Hut.
New wiring harnesses and fuse block from Garry the EFI Guy.
Reprogramed PCM from Garry the EFI Guy.
I have all of the parts and accessories for the engine as you can see in the pictures . I even have the stock cast iron manifolds if you would rather run those. I have rebuild kits for the fuel injectors too. Everything that you need to swap this into your Bronco all in one "kit".
I would like to get rid of the entire "kit" and I'm asking $3,000. Not interested in splitting up at this time.
