blazinchuck
- Jul 14, 2005
- 3,319
i need some quick help. ive already done the explorer serp conversion...but now im second guessing myself. after reading some tech...i keep seeing that there is a dowl pin that needs grinding and a cam shaft bolt head that need grinding for clearance using the explorer cover. i dont recall any issues other than removing the fuel pump eccentric. once i did that, i replaced the washer/bolt and tightened. the crack turns fine and i dont feel any interference in the cover. im hoping yall can tell me if these mods were more needed on the older 302's getting this swap??
i just dont want to remove everything ive done and painted, just to replace more gaskets, more cleaning,etc....only to find its all ok and there was plenty of clearance between the cam shaft bolt and back of the cover.
