Ok. So I have read that 78-79 Bronco brake cables are the way to go for a lifted Bronco. My bronco has 3.5" lift springs with a 1" body lift. The rear axle is a 77 F-150 rear axle.
Do you recommend that I use both sides, or two that are the drivers side?
Thank you for your help!
