casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I'm tracking down a couple oil leaks on my 351w.
Leak #1 is from the dipstick tube. This is the screw in style dipstick that goes into the pan. Should this dipstick have an O ring to seal it or is it just a pressure seal? It had no O ring before so I put one on and it still leaks. I think its worse with the O ring.
Leak #2 looks to be from the back of the oil pan but Im not 100% sure. My original thought was rear main seal but when I pulled the transmission inspection plate, it seems to be dry as a bone in there. Wouldn't my flex plate and torque converter be covered in oil if it was the rear main? I'm a little surprised that the oil pan gasket would be leaking as it is the one piece style and it is less than a year old.
I'm considering pulling the pan to try to seal them both up and I'm considering going with a flexible tube style dipstick.
