Bundy
- Jan 10, 2009
- 2,045
i am trying to trace a decent leak that starts with my NP435 or the D20. after scrubbing/dregreasing i drove it for a bit and the there was oil on dripping from the bottom of the D20, but not as much from the tranny.
there is no obvious leak from the output shaft, i can't see where the tranny and the TC mate because of the crossmember but this seems like the culprit.
on the D20, there is a lower drain plug and it looked like two fill plugs- one was way too low to be the right filler and the second it about 1/3 of the way up. when i opened that fluid came out and i closed it quickly. i think i read it holds 1.5 or two 2 quarts?
the NP435 took about a half a quart, not alot but more than the TC. i think i read it takes 2 or 3 quarts?
Anyway, my main question is could it be the gasket that seats the TC and tranny? also, my tub is rhino lined over the tunnel but i can see screws under the lining and can make out what i think is a removable tunnel panel. before i rip up my lining, i want to make sure it will tell me something.
thanks!
thanks!
