airbur
Are the widebands in place of the regular o2 sensors in the exhaust?
Congrats on getting the bronco running! Was that you wife saying it was "so loud" ;D That was the first thing my wife said when I started it the first time too.
Henry
I have zero experience using SCT, I don't use them because of politics, not because they are inferior. If it wasn't for SCT most of us would still be in the dark for tuning early Fords. That being said, tuning a Ford is pretty much the same no matter which way you go. Most of the screen shots I've seen of various programs look almost identical.
I'm sure that SCT does dumb it down quite a bit. I think you can just enter which injectors and MAF you are using and it automatically enters the values. Whereas with a QH you need to enter it manually. This isn't too bad to do if you are using parts with known values, and it looks like you are. Templates are pretty much readily available for this and it makes it pretty much copy and paste.
I'd still be lying if I said there wasn't a steep learning curve. The biggest thing is that it is just overwhelming at first. If you take it in little steps it isn't so bad. The hardest part by far is dialing in your idle. I still use a little notebook that I have taken notes in to dial in idle.
I have no idea how SCT's pro tunes do this correctly without some way to real time data log. I've played with very similar engines quite a bit and they all seem to like different values. So I'm not sure how that works, but real time data logging is just a must have feature IMHO.
The other thing I have noticed on a few of the "canned tunes" I've seen is dumbing down of tables. Like disabling all of the various altitude spark tables and only using the sea level table (just one example). This works great and simplifies it a bunch (especially for drag cars), but I believe some driveability is sacrificed here. Especially for those of us that may have a 7k feet change in altitude throughout the day. I believe the Ford engineers had good reason for the various tables, so I leave them be, unless we are talking a drag car. I use all the tables daily driving my Stang, and switch to the "simplified" set up when at the strip. Now I'm not saying SCT does this, I don't know if they do or not, but it is common practice in a lot of the "canned tunes" I've seen.
Anyway, that's my take on it. If you decide to go QH, I'll come spend a couple of hours getting you dialed in. You can later get it perfected on a dyno, but once your tune is perfected you shouldn't have to fiddle with it at all. If you decide to go SCT I won't blame you a bit. Sometimes simplicity is just best.
No a wide band is an additional sensor that goes to an individual gauge you can mount in the cab so you can monitor your air/fuel ratio
Awesome! I too know the feeling, nice work!
...On the timing, I presume you have a timing pointer and correct marks on the balancer? You'll disconnect the spout and set it at 10 degrees BTDC. Once it is set the computer will take over.
