- Nov 11, 2007
- 7,805
OK< after three versions of motors built and dry stored for my continuing saga:
I finally dropped dime on the 347 stroker seen here, custom cam by Fordstroker.com, 9.7:1 comp ratio, program estimates 400HP and 400 ft-lbs at 4000rpm. 650cfm Truck Avenger out of the box, edelbrock performer heads, performer intake. Duraspark converted to mopar HEI internals and control module by Ignition Engineering in Ca, curved to the camshaft. Magnaflow mufflers, sound good, not sure if I want that loud, but sound good. Ceramic headers saved until after install and one hour of breakin. KB semi stepped flat top Hypertetic pistons. Explorer serp front. Canton 7qt oil pan. Balanced to 28oz.
First test, started on first try, very peppy. My machinist was very impressed with camshaft.
Lets see if anyone picks up whats wrong with the front of the motor while its running...
No, not the no airfilter, or the fact an electric motor is turning water pump...
http://s267.photobucket.com/albums/...w¤t=photobucket-43429-1354339853036.mp4
