Ford Godzilla Crate Engine
ssray
South Central NE
Just noticed this post from 2020 below. Maybe C delayed Megazilla?
hossbronco
The Megazilla is supposedly a twin turbo. While that should mean even more hp than a supercharger, the supercharger would be better-suited to most Bronco drivers.
hossbronco
I just put my 427 long block up for sale; planning on going with a naturally aspirated Godzilla, probably around 600 hp, for now. I could go higher hp but want to keep as much low end torque as possible as this is still a street Bronco that will spend most of its offroad time in the rocks.
Before I do irreversible damage by selling my new engine, someone please explain why this is a bad decision. The drivetrain is already built to handle much more power than this (fully built 6R80, Atlas Pro 3.0, upcoming 609s with 5.43 HP10s and 40 spline 300M shafts). The Godzilla would bolt directly to the 6R80 and not only give me another 70 hp at the flywheel (with the ability to go higher), but remove the Speed Gems adapter that would likely leach another 30 hp at peak.
Certainly there will be clearance issues to work through, especially with my HP10 in the front. Aside from the increased cost, why shouldn’t I do this, given my goal of a reliable trail/street rig that is fun to drive in all conditions?
Probably need a new 6R80 case to put your good parts in. Bellhousing pattern is different.
reamer
Why go through all that, when Edelbrock makes the Pro-Flow 4? real fuel injection (not a crap sniper on Fitec) Bolt on intake and go.....
I installed Pro-flow in less than 12 hours....
hossbronco
I spoke with a guy at PBH Performance who told me that the 10R80s aren’t holding up to the abuse their customers put them through. I’ve always heard the 6R80 is stronger, but it sounds like the difference is larger than I expected. Part of this could be because there are currently more parts available to beef up 6R80s at this time.
hossbronco
With the aftermarket balancer the overall length should no longer be the limiting factor. still wide but doable, fender mods are way easier than firewall mods. I can say from experience swapping "other" engines in bronco's that a cowl hood will cover it with no body lift. 2" body lift and it should clear a stock hood just fine.
Which aftermarket balancer are you referring to? Is it part number 918073 by ATI Racing? I’m trying to find a pulley system that will support my hydroboost brakes and a big alternator, while fitting inside the engine bay. I’m looking at CVF Racing’s system, which uses this balancer. Does the balancer you’re referring to shorten the length of the engine?
Jmjuhl
Jmjuhl
Newbie
Cypress, Texas
Indy Power Products referenced the aftermarket damper in their diagrams, which is the ATI damper. I think that diagram also included their water pump (off a 93-95 T-Bird I believe)...which fits on their billet timing cover...with their serpentine setup...which works with their oil pan...yada yada. That is where it got expensive...great that one vendor has a solution but its about the cost of another crate engine to make it all work. Probably worth a call to them to better understand it.
Yeller
Rogers County Oklahoma
This was my reference as well
hossbronco
It’s a good compact system, but it’s expensive, as you said. If you’re looking to shave a couple of inches off the bottom of the oil pan sump, Danbury has a much cheaper, though still expensive, solution that modifies the original pan. It also has an optional oil cooler delete and oil filter relocation if pan width is a concern.
https://danburycomp.com/product/ford-7-3l-godzilla-shallow-oil-pan-kit/
The Indy pulley system and the CVF system appear to use the same damper, but the Indy uses the grooves on the damper ( and the CVF attaches a pulley to the end of the damper. They both appear to protrude about the same at the damper, but the Indy pulleys are in tighter.
Jmjuhl
Jmjuhl
Newbie
Cypress, Texas
417 Motorsports also makes a shallower pan as well...designed for the Fox Body mostly.
Just saw this video this morning...Gumby is starting a 7.3 Godzilla swap on 77 using a Mars pull out...guessing they are using the Mars modified control pack to run the 10R80 as well. This will be a fun one to follow along with.
