samjaxfl
I installed a fuel pressure gauge and regulator, during the install had a noticeable leak. After cutting the motor off to fix the leak it took no time for the gauge pressure to go down to 0, seemed normal since fuel was dumping out. I fixed the leak, went for a drive and after shutting the motor down the pressure remained at the gauge, seemed normal since no fuel was being used. This morning I go out and find the gauge at 0, is this normal after sitting over night or does it indicate I might have a smaller not as noticeable leak? What is the normal time frame for the fuel system to unpressurize between the pump and the carb?
