msommer001
- Jan 15, 2009
- 391
Can I be filling my tank to full? I have been having trouble with the bronco stalling. I thought vapor lock so I relocated the gas line to outside the frame.
Then tried again, nonissue driving to the store, a 3 to 5 minute drive. Then on the way home stall. Engine was warmed up but it was not a hot day outside. I would wait about 3 to 5 mins and bronco fire right up, I would drive for about 30sec to 1 minute and then stall. I repeated this for 3 or 4 times until I was back in the garage. I also removed the fuel cap to see if venting was an issue, it did not help.
The tank was full at this point. I started to empty the tank so that I can lower it to see if there is a blockage in the tank and noticed that the filler neck has a significant crease/fold in it so that it connect to the tank. It is not the 2 part filler neck. When I loosened the filler neck and vent hose fuel spilled out of both.
Can the filler neck and vent not allowing air into the tank create this intermittent stall?
Either way I plan to install the correct filler neck to eliminate the possibility.
