- Dec 4, 2010
- 963
Have gathered most of my stuff for the Hydro conversion and am seeking advice on the proportioning valve. Front disc / rear drum. Stock MC setup has front going to rears and firewall of MC going to fronts, so I'm just run with that on the new setup.
I'm wanting to do away with the H-block and go with just one control valve. That valve goes in the line to the rears, right? (restrict flow to the drums?) Is there any reason to keep the H-Block, other than the warning light? Mine has been out for years. Looks like the 76 and 77 had a fancier H-block, but I'd still like to lose it.
I think it would be more fun to do a few test runs and dial it in once I can lock up all four, don't you?! Please let me know if that block is necessary.
Also, any suggestions on a good power steering fluid cooler, maybe from Summit? Think I found one that's good. Thanks for any help and here's my progress so far. Working on the 1/2" adapter plate between the HB and MC.
Cheers, B2
Cheers, B2
