Ok. First the specs:
1972 Bronco
302 C4 automatic
Changed original fuel tank to 23 gallon
Changed to a smaller barrel type air cleaner (tried the larger but wouldn't fit)
Ran pretty good for about a year after install (runs better in cold weather)
So basically I'm having trouble cranking the bronco after it's been running for a while. (For example I drive it out to get some food. Come back out to the parking lot after eating. Have a super hard time cranking it.) I basically have to pump the hell out of the gas and eventually it catches and cranks (sometimes takes so long to crank starts to smoke under the hood). Usually dies immediately and then cranks on the next try. I feel like I'm manually pumping the gas with the pedal all the way from the tank. It's also been having more and more trouble cranking even on a cold start now as well.
I don't know if it's effecting it but it has been running hot at times on really hot days when I run it a lot. Once it started steaming the radiator fluid when I was stuck in a drive thru after running hard a while on a really hot day. Pulled it off to the side, let it cool down, and it was fine after that.
I'm wondering if I have a fuel pump going out or some other problem I'm not even thinking of. It's getting to the point where I'm starting to get scared I'll be stranded somewhere.
Anyone have any ideas? Thanks!
1972 Bronco
302 C4 automatic
