I've run into a bit of a snag. The first set of headlights had glass lenses and plastic housings that were very easy to remove with the oven method. I cracked the first headlight trying the heat gun method (see first page - do not use the heat gun!!!).
I have another set of headlights but I can't get the lens off!!! Its the same glass lens but has a fiberglass-type housing. Baking at 300 for even 20 min didn't do anything. I'll try again with 400* later today or tomorrow. If that doesn't work I'll have to find another set of headlights with plastic housings.
So just another FYI - if you do this, look for headlights with plastic housings, not fiberglass.
