- Mar 30, 2004
- 715
OK. My 73 has a 302 with a Schneider cam, headers, and a Edelbrock Performer and a Holley Truck Avenger 670. My carb will allow the truck to start at high idle. It will then ramp down to low idle. If I try and raise the RPM's, it dies/sort of turns off. It does not backfire. the fuel pump (mechanical) pumps like a banshee. I think all of the vacuum lines are ok. I am not 100% sure about the carb to manifold plate/seal. I did not check this yet. What is going on? Why will it not let me drive the truck? It behaves like someone just turns it off when I press the peddle. At a high idle, it goes/sounds fine. Make sense to anyone?
