bronconate68
The problem; once motor came to temp. the Holley stumbles and dies at idle.
I finally fixed all exhaust leaks, blown out header gasket and both flange gaskets toast with the first 10 miles. The motor fired right up, start of first crank. Ran great for about 3 miles then die at a light. Took some cranking and giving it some gas to get started again. Clear fuel filter at carb mostly full. Drove back, only one stop, put it in neutral and gave it a little gas to hold idle. I pulled into my driveway and took my foot off the gas, the motor choked out right away. Drives fine when driving down the road, stumbles then stalls at stops. 800 rpms then 700, then drops then dies. Needs a lot of coxing to get started, in my driveway I finally held the throttle to the floor to get it to fire up. Any tips on Holley adjustments would be great. This is my first Holley; 770 CFM Off-road truck avenger, motor-408 stroker.
Thank you,
Nate
'68
Thank you,
Nate
'68
