I have a Holley Carb that has list-1850-3 and the # 2111 stamped under that. after it warms up I have issues with it cutting out and rendering it un-drivable. I can normally wait until it cools down and will be able to drive it again. the issue Is with the fuel delivery. I know it's fuel because when I look down the horn I can see the fuel stop pumping into the throttle body when it starts to cut out...
I've owned it for about 2 months and have replaced the fuel sender, cleaned the tank replaced the fuel line, the fuel tank switcher ( from manual to 12V off the Tank toggle), fuel filter, and now the fuel pump. I went through the float adjustment on Holley's website and adjusted the fuel in the bowls so it is just barley trickling out of the windows like it said to. I figured I had to be getting close, so in a last ditch effort I pulled the vacuum hose off between the carb and distributer and plugged both. everything seemed to clean up and I was able to drive it up the block and back. ( Im a little gun shy about getting to far away) .
My questions:
1) Is that vacuum line necessary?
2) I'm guessing that has something to do with Timing?
3) was my problem the timing all along?
My questions:
