BroncoMedic23
- Jun 11, 2022
- 3
Installing WH 1973 OEM horn. Inspecting the wires designated for the original horn, there is a yellow and a black and judgin by the connectors, the yellow is the lead with a female spade connector and is intended to connect to the horn at the male spade. The black with a fork spade is the ground which I connected to the mounting bolt for the horn itself. I dont think its supposed to mount to the adjusment screw and thats the only other alternative I can think of. A little description of the electrical status. When closing the loop between the yellow lead and black ground there is power. With the lead attached, any contact with the adjustment scrwe to a groiunded item causes the horn to sound. So I know I have power getting there and that the horn works. This leaves either the location of the ground wire or a problem with the horn button assembly. My assumption is that the horn activates when the button is pressed by closing the loop and replicating what occured with the adjustment screw. I'm hoping I dont have to dismantle the steering column but will take any suggestions to identifyig the culprit or how to fix. The hazards dont work either but turn signals, brakes lights, reverse light do. The 20 Amp fuse for hazards is in tact. Any help would be very much appreciated.
