TBS-POPS
Swapped my Edelbrock 1406 for Howell TBI and my 302 has never run better. I had the carb set up really good and it ran awesome even at altitude on the Rubicon but the TBI seems to have really woken this old motor up. This is truly plug and play fuel injection that is way simpler with less headaches than Ford injection for a fairly stock or slightly warmed over engine.
Simple install. remove carb, install tbi unit, o2 sensor, water temp sender, electric fuel pump, hook up wiring harness, 1 ground, 2 12v conections, fuel pump wire hit the key and go!! The hardest part is figureing out how to get the harness inside and where to mount the ecm... Its really simple!!
