John_parkeriv
So I've just finished installing my HB/PS setup on my 351w. AN lines were an absolute nightmare to put together, but they all seem solid and not leaking. I pour steering fluid in the Saginaw pump and fire the truck up. Sounds fine, the I turn the wheel and it screeches like a banshee. Try to use the brakes and it screeches too.
"Oh," I thought, "New PS parts, probably need to bleed the system out." Jacked up the front of the bronco, held the brakes down, and turned the wheel lock to lock about 5 times. Fluid and bubbles spewed out everytime I made it to full lock. Refilled the reservoirs, and redid the bleeding about 25 LTL's. No matter how much I turn it, and how much fluid I add; it just keeps on bubbling.
At this point, I'm suspecting an air leak somewhere as all the fittings still seem leak free. I've seen guys test the new remote reservoirs with a rad pressure tester, but how would you test a Saginaw?
What's the best way to ID the leak with a canned ham pump? Also, just to be safe, the feed line from the pump goes to the passenger side of the HB (the side with the gas canister), right?
Thanks!
Thanks!
