67EB_in_619
So I am trying to help a buddy with some ignition wiring challenges... he swapped his ignition switch, coil, and starter solenoid because he was chasing a problem that turned out to be bad plugs.
Anyway, behavior is as follows:
Truck will crank and start but when key goes back to RUN, it dies.
Confirmed that ignition switch (OLD and NEW BOTH) dont have power at ign+ when key is in RUN position.
Let try to show this with a table of data:
@------------ACC Key Position---OFF Key Position---RUN Key Position
BAT Wire----12v------------------12v------------------12v
IGN Wire----12v------------------0.2v-----------------0.2v
ACC Wire----12v------------------12v------------------0v
I have been helping over the phone and expect to put eyes on the bronco later this week... but what I have "confirmed" is that the ignition switch behaves the same if it is the OLD or the NEW one.. while I get it is possible to get a bad new switch, having it bad in EXACTLY the same way seems like a stretch. I have confirmed that the starter solenoid has the purple wire on the S post, and the white wire on the I post (centech harness). The white wire goes through a ballast resistor to the + on the coil. He can "hot wire" it by jumping a wire from battery +12 to the I post to keep it running (how he plans to get it over here later this week).
I am at a loss as both switches seem to be behaving oddly unless there is a short or something downstream causing it to back feed the ign with the acc power, but it doesnt explain why there is no juice @ RUN.
I plan to hot wire things from the switch to see if that makes it behave differently, but aside from cutting into the harness, what suggestions to you smart fellers have?
Thanks in advance.
Thanks in advance.
