377
I'm hoping somebody might be able to help me out here. I'm building a new rig and have run into a major problem with my headlights. First I'll give you some details on my project. The body is a bronco design fiberglass tube on a 1974 frame. Wiring harness is a new American Autowire Harness and it has a Toms Bronco Parts Headlight Harness/Relay. When I initially installed everything there were no problems at all everything worked as it should. One day I'm messing around and hit the dimmer switch and no bright ligh indicator. So I walk around to the front and no power at any of the headlight connectors. I check my ground and power feed for my headlight harness everything was fine. So today I take out the new headlight switch and replace it. Everything is working as it should be. So I stick it back in dash and it's not working again. So I jiggle the headlight switch knob I notice my high beam indicator comes on and I have headlights. I also notice while doing this a noise coming from where my headlight relays are mounted. Kinda of a click noise. So I continue jiggling and it keeps going on and off. During my last session of jiggling I noticed a tiny bit of smoke come out of my vent area. I immediately disconnected the battery and removed the switch from the dash. Once the switch was out of the dash I hooked the battery back up and jiggle the switch. It didn't do anything at all. I inspected the wiring harness for any signs of melted wires and didn't find anything. The one constant with both switches and whether headlights worked or didn't is my tail lights,courtesy lights and gauge lights work fine. Based on the clicking noise coming from the relay mounting area I really suspect something going on there and possible back feeding from there caused my tiny smoke show? I also noticed when the headlights aren't working the high beam indicator light has a very very faint glow no matter what position the dimmer is in. This also makes me suspect some kind of back feed also? If anyone has run into this kinda problem before and could give me some guidance I'd greatly appreciate it. This project is supposed to be an enjoyable retirement project and has turned into something that just pisses me off! For what it's worth this isn't the first from the ground up vehicle I've built. I have just had more problems with this thing then all the other rigs I have built. Sorry for the rant this thing has just come to the point of being more annoying then anything. Thank you in advance for any help you can give me..
