pclancy
All,
Thank you for your help with this question.
Ever since the weather turned a bit cooler (I live in Washington DC, and this will be my first winter with this truck) I have noticed that I can't seem to get my engine to run hotter than about 150 degrees. My driving is mostly in the city, and this is what she reads (with an aftermarket temperature gauge that I believe is accurate) after 30 minutes of running in 40-50 degree weather.
I have a bone stock 302 in a 1969 Bronco. Stock radiator.
In the summer, with the temperature in the 80s and 90s, she runs at between 180-190 degrees.
The heater works just fine.
I have yet to see what the story is with my thermostat--plan to do that today. Have never checked.
But my Bronco Doctor/mechanic said not to worry. Should I? What degree thermostat should I have in it? Is it OK if it runs this cool? What temp should the engine warm up to in winter?
I am not a mechanic, so your advice is welcome!
